Hi, so I bought my ssd  a year ago, and I mounted it and installed OS on it, turned to AHCI option and it is in Sata II from an intel port asus P7p55d-e pro.
So at the time I didn't moved anything from my HDD to the SSD, and also left the os on the HDD because and Still don't have where to put my important stuff from the HDD (still waiting to buy a green HDD to put all the crap in there.)
But at the time I ran the tests and speeds were ok I think. 51945/18248  270/186  those were my benchmark results when I settled for it. but now a couple days ago I ran it again and I got shcoked. 51412/9080  270/94
So for some reason my write speeds got cuted by HALF... and Idk what else is worse.
I don't have any other benchmarks besides the magician ones from that time.
Please help me. I've been looking for answears for hours.
https://linustechtips.com/topic/110064-samsung-840-problems/
Ran TRIM?
My Personal Rig - AMD 3970X | ASUS sTRX4-Pro | RTX 2080 Super | 64GB Corsair Vengeance Pro RGB DDR4 | CoolerMaster H500P Mesh
My Wife's Rig - AMD 3900X | MSI B450I Gaming | 5500 XT 4GB | 32GB Corsair Vengeance LPX DDR4-3200 | Silverstone SG13 White
https://linustechtips.com/topic/110064-samsung-840-problems/#findComment-1470471
Have you forced it to run trim also how full is it and how much use has it gotten.
https://linustechtips.com/topic/110064-samsung-840-problems/#findComment-1470520
I enabled TRIM at the time, it is on. I don't know how to force it. It was pretty full I clered it up to 46GB and I don't really use it a lot besides downloads and erases from it. no photoshop or hard programs on it. 3.66Tb of usage in 1 year usage
it is 250Gb version
https://linustechtips.com/topic/110064-samsung-840-problems/#findComment-1470528
How much free space did the drive have when you ran that benchmark?
Workstation: 3930k @ 4.3GHz under an H100 - 4x8GB ram - infiniband HCA  - xonar essence stx - gtx 680 - sabretooth x79 - corsair C70 Server: i7 3770k (don't ask) - lsi-9260-4i used as an HBA - 6x3TB WD red (raidz2) - crucia m4's (60gb (ZIL, L2ARC), 120gb (OS)) - 4X8GB ram - infiniband HCA - define mini  Goodies: Røde podcaster w/ boom & shock mount - 3x1080p ips panels (NEC monitors for life) - k90 - g9x - sp2500's - HD598's - kvm switch
ZFS tutorial
https://linustechtips.com/topic/110064-samsung-840-problems/#findComment-1472269
it is 250Gb version
Ill have to check mine in my laptop what im getting but whenever you do a clean install its best to do a secure erase and start fresh.
https://linustechtips.com/topic/110064-samsung-840-problems/#findComment-1472463
run a few more tests. i just ran the benchmark on my system and i got the best result on the third run, this is witht he ssd abouit half full, used as a c drive.
no idea why benchmarkk is in that language, but that shouldnt matter to the results
first run
second run
third run
8700K
https://linustechtips.com/topic/110064-samsung-840-problems/#findComment-1473361
