Help
Solved by AndrewB121,
4 4k monitors is 8k. I doubt even a 2080ti could game at 8k at playable framerates, let alone stream. If I were you I would find a high resolution ultrawide monitor for gaming and perhaps pair that with a smaller 1080p monitor for stream/youtube/spotify or whatever it is you do on the extra screens.
I don't think you can have a seperate card dedicated to one screen in windows, and if you can you definately can't have 1 game run the two cards.
