Hello guys,
So I have felt like it was time to get a new PC and i did not want to get myself a prebuilt, as its way more expensive.
I have already watched quite a view videos and reviews of the components i want to use. I am worried I will run into trouble or selected the wrong part somewhere.
1. Budget & Location
The budget its around 2000€ and my location is Europe, Austria
2. Aim
I will use this PC for high (ish) end gaming and probably some light video editing.
3. Monitors
I am planning on running one MSI Optix MAG271CQR 27'' monitor for now but this will probably change to two monitors in the future.
4. Peripherals
I will just need the monitor as i got my other equipment.
5. Why are you upgrading?
I am currently running one ok ish PC that can run games like overwatch one low to medium detail but i want to be able to play some demanding games too and that i dont have to go with medium to low settings with shadows turned off. I also want to get a pc that i dont have to update in the near future to keep things going.
So my current plan is this:
With the MSI Optix MAG271CQR 27'' monitor.
EDIT: I will use the Giagabyte X570 Aorus Elite instead of the AsRocke X570 PG 4
If you have any suggestions on what to change/add please tell me.
Many thanks
Andiq
https://linustechtips.com/topic/1099557-build-plan-for-myself/
2080S hardly gained anything from 2080. How big is the price gap?
That board is one of the weakest board on X570. I'd spend more here
Samsung drives are overpriced, plenty of other NVMe SSDs do better for what they are, say Adata's SX8200 Pro, HP EX920/950 and Corsair MP510 are just as fast for usually cheaper, or the Sabrent Rocket which is usually close in price but faster (PCIe 4.0 after all)
The fans for where? The case comes with 2 120mm fans, while the 2 140mm can go either up top or the front. In the former case you should still get another 2 120mm, in the latter 1 extra 120mm (as it can hold 2 140mm or 3 120mm in the front).
Desktop benching:
https://linustechtips.com/topic/1099557-build-plan-for-myself/#findComment-12852589
That actually looks pretty solid specwise.
Won't go into details, but I can tell you this much for sure.
1) Get an additional HDD/SSD... You'll need to store games somewhere, and 500 GB won't allow you to "stretch your legs" with modern AAA-titles.
2) Don't forget to overclock your memory (CPU and GPU are kinda obvious rn) and improve timings. Sweet spot in terms of perfomance is 3600 MHz. Below or above that speed you won't gain more perfomance. Here's more info on that:
3) Samsung SSDs actually have the biggest amount of GB that can be rewritten on their SSDs (it's something that russian site 3DNews tests for a long time now actually, and point still stands).
4) Can agree about 2080 and Super version, unless gap is less than 60 Euros. 8% perfomance bump in fps isn't something that worth a lot, you know...
Purify your Windows 10/11, don't give Microsoft anything that you don't want to share.
https://drive.google.com/open?id=1ZwVs9zrM493rjD42E2Pf0YcOkaW92ZUo
Tips for folding on laptop:
Lazy man wants upgrades from the sky.
https://stats.foldingathome.org/donor/Spakes
https://linustechtips.com/topic/1099557-build-plan-for-myself/#findComment-12852599
I was thinking about putting the 2x140mm in the front and the spare 120mm on the top does it matter that much whether i put two 140mm on the front or 3 120mm ?
I know that Samsung is overpriced it was just a placeholder till i get a suggestion or till I find a better one as i didnt really search that much for storage.
Im thinking about getting the Gigabyte X570 Aorus Elite now.
There is a price difference for about 60-70€ between the 2080 Super (because the KFA2 is so cheap) so i think it is worth it for me
Edited by Andiq1
prices for the RTX 2080
https://linustechtips.com/topic/1099557-build-plan-for-myself/#findComment-12852606
6 minutes ago, m777y said:
sry if over budget.
i mean just don't go to that kfa2. cheap plastic build quality, feel bad cooler.
better 2080 super nvidia edition (official), if you find it.
Ive actually watched a review where he compared the two and got like 15% better thermals then the founders edition
https://linustechtips.com/topic/1099557-build-plan-for-myself/#findComment-12852746
https://www.youtube.com/watch?v=u1lSIg2lxTg
https://linustechtips.com/topic/1099557-build-plan-for-myself/#findComment-12858730
