Hey all!
I've recently finished building my pc and got a set of (supposedly) ARGB fans, but I found out that my motherboard is missing the ARGB pins, even tho it was advertised as them being there.
Now I don't want to change the motherboard, but I do want to get my rgb working.
Motherboard: Gigabyte B360M HD3
https://www.gigabyte.com/Motherboard/B360-HD3-rev-10#kf
Fans: Silentium Stella 120mm ARGB
https://www.silentiumpc.com/en/product/stella-hp-argb-120-pwm/
The fans have 2 separate cables, one which goes into the power slot and one into the rgb slot. Both cables have extensions, so you can connect your fans speed and/or rgb together.
The PWM is a standard 4 pin cable
The RGB one is a split end cable that turns into a 3 pin cable using a convertor
Question is, what rgb controller do I need to get them to work, or can I diy the ARGB pins onto my motherboard?
https://linustechtips.com/topic/1098556-help-with-rgb/
https://linustechtips.com/topic/1098556-help-with-rgb/#findComment-12846263
