Hey guys this will be my first build and I don’t know what I am doing. Does anyone know someone in Colorado willing to help put it together? Or can someone walk me through it? I was able to get the cpu chip in the board, I think I put the trident z’s in the right spot, I installed the m.2, and set up the spots for where the fans will go.
Also need windows. So if you know of a liable cheap source that would be greatly appreciated!!!!
Here’s what I have:
https://linustechtips.com/topic/1096816-build-help/
Well, there are a lot of build guides on youtube, like the one our boy Anthony made
Not sure how the watercooling works, but with everything else you just gotta remember a few key concepts (ram in slots 1 and 3 or 2 and 4, align the golden triangle,etc) and then follow the instructions on the motherboard manual to check where all of the case cables go in. For the psu cables what they're used for is usually written on them
https://linustechtips.com/topic/1096816-build-help/#findComment-12830559
