Problem with my ram
Go to solution Solved by JW_Weingarten,
That wasn't there when i commented
ok that is strange.
P.S update : My ram has been acting normal again.
Hello,
At the end of October i bought my gaming pc. Since a month or 2-3 i have been noticing my ram is acting stange.
A lot of times it just jumps up to an usage of 98%. I check my task  manager and i see something like this http://gyazo.com/de7508ebdcb737b354c67ef2af73e7d0.png
I only have chrome running and even when you add up all the mb its taken it is nowhere near the 8gb of ram i got.
Even when i close chrome and other programs, my ram usage sticks at +90%. The only way to make it go down is to do a full restart.
It is happening a lot and my pc also starts slowing down pretty badly.
I did some scans and did not find any virus or infected stuff.
Please help me
My specs:
- MSI Z87-G45
- GTX 770
- i5 4670K OC to 4.0Mhz
and of course my ram Corsair vengeance 2x4gb ddr3-1600
Windows 8.1 64 bit
Edit: http://gyazo.com/6f3d011020b1dfa80e5234efb73c2945.png when i close chrome, skype and the other junk my ram drops to like 80% and when i open it back up the usage raises to 90-100% again.
https://linustechtips.com/topic/109668-problem-with-my-ram/
Go into task manger and click processes and see whats using it all up...
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/109668-problem-with-my-ram/#findComment-1465440
A friend suggested to update my bios. I updated from 1.2 to 1.6.
15 minutes in now. Opened chrome, downloading some other drivers and i have skype open and it is sitting at 33% ram usage.
Hopefully it stays this way.
i will update the thread in 1 hour and let you know if its still going good.
https://linustechtips.com/topic/109668-problem-with-my-ram/#findComment-1466526
Please read my post and check the link i included....
https://linustechtips.com/topic/109668-problem-with-my-ram/#findComment-1469060
ok that is strange.
Thats good to hear!
https://linustechtips.com/topic/109668-problem-with-my-ram/#findComment-1469219
