3 minutes ago, Elee said:
Being used for editing, recording and gaming
https://uk.pcpartpicker.com/builds/edit/?userbuild=PqFtt6
Also, which resolution? Which games? Which software? If you have a monitor, which one? If you don't, do you need one? Budget?
I cannot check budget or monitor on the list as it is not public.
Resolution: 1080
Games: literally anything everything
Software: Premiere Pro and Stream Labs
Monitor: Alienware 25
Budget: £1300 Max
copy the permalink and paste it, wait for the parts to show and then submit the reply. makes it easier for us to make changes.
10 minutes ago, Elee said:
CPU
AMD Ryzen 7 3700X 3.6 GHz 8-Core
£319.99
Yes
Motherboard
Gigabyte X570 GAMING X ATX AM4
£174.67
If you want
Memory
Kingston HyperX Predator 16 GB (2 x 8 GB) DDR4-3200
£83.75
Ok (I would get Corsair LPX, but personal preference)
Storage
Intel 660p Series 512 GB M.2-2280 NVME SSD
£56.10
Ok... But depending on resolution and frame rate of your recordings that may fill up real fast
11 minutes ago, Elee said:
Storage
Toshiba P300 3 TB 3.5" 7200RPM
Ok
Video Card
MSI GeForce RTX 2070 8 GB
£461.17
Nononono
Unless you really need RT, get a 5700XT (like the Sapphire pulse
Case
NZXT H500 ATX Mid Tower
£64.99
Not really the best airflow... maybe get a meshify C if you can
15 minutes ago, Elee said:
Power Supply
Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX
£73.49
Thats good
