Best would be something like the Dark Rock Pro 4 or Noctua NH-D15, but this depends on the case you plan to use it in, how tall your RAM is etc...
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1095647-cpu-air-fan/#findComment-12820600
THese are indeed the best air coolers on the market. They do cost close to $80. But are very nice. Not sure if it makes sense for such an old CPU to buy such a nice cooler...
The Coolermaster Hyper 212 Evo is a long time favorite for more budget oriented performance. It costs something like $30. You wont get the performance of the more expensive models, but it performs very well for the cost.
https://linustechtips.com/topic/1095647-cpu-air-fan/#findComment-12821220
  • 2 weeks later...
What case and ram are you using? Are you oc'ing?
Where are you shopping / located? Budget?
Moved to Air Cooling.
https://linustechtips.com/topic/1095647-cpu-air-fan/#findComment-12849075
Case: Cooler Master CM690 II
OC: Nope, wont be overclocking
Located: South Africa
Budget: R1000 max
Shopping: SA Online stores
Moved to Air cooling: Yes, currently my 2700k is using the corsair h100i v2, I want to use the h100i v2 for my upgrade which is a intel i9 9900K, so just want a good air cooler for my i7 2700K.
https://linustechtips.com/topic/1095647-cpu-air-fan/#findComment-12853355
3 hours ago, Apples ZA said:
Ok, thats fair, what do you recommend then.
I found a cooler master hyper 212 turbo brand new for R600, was gonna for that
A Hans would be better: https://www.wootware.co.za/reeven-rc-1205-hans-120mm-fan-black-and-yellow-cpu-cooler.html
https://linustechtips.com/topic/1095647-cpu-air-fan/#findComment-12853839
