Hi, I can't get my discord working because I need to verify my phone, but it didn't work the first time, possibly because of a typo, and now it's saying I'm being rate limited. I've waited roughly a day or two, and it still says I'm being rate limited. What is the rate limit time on this, and how can I expedite the process on getting my number verified? I didn't find any topics on the forums already about this :(. Thanks for your help!
https://linustechtips.com/topic/1095063-discord-issue/
When you say 'verify phone', are you trying to add a phone number for something such as 2FA?
If your phone number has been entered, are you able to remove it?
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/1095063-discord-issue/#findComment-12816051
3 minutes ago, Queen Chrysallis said:
Idk, in my case i just removed the phone authentication and 2FA (which asks for password), then waited until the rated limited wore off then set them up again, mine took around 2-3 weeks iirc, i wasn't counting, i still had full access to my discord account in the meanwhile tho
also quote or tag people otherwise they dont get notified that you replied
Thanks. I have 2FA on discord already enabled. I will just wait for the 2-3 weeks before I can use the LTT discord. Thanks for the information. I still have the forums in the meantime.
https://linustechtips.com/topic/1095063-discord-issue/#findComment-12816131
