Advice on choosing the right Monitor
KurodaAkira
Hello there,
I am currently searching for a new Monitor to upgrade my rig.
This is what I am currently using:
Computer has a GTX 1080 for the main monitor (which I intend to replace) and a GTX 1050Ti for my two other monitors.
All three monitors are BENQ GL2450 which I had for quite some time.
My intention is to get a new main monitor and continue using the current one as my 4th one (and yes I really need a 4th).
To properly set the monitors up the new one should be a 24" monitor and 1080p.
Since it should also be an upgrade, I was thinking of getting one with a higher refresh rate (144hz) and a better pixel response time.
Since my other monitors are not curved, I don't think getting a curved one would be a good idea.
Unfortunately I don't have much experience with picking monitors as my current ones have accompanied me since my first own desktop computer.
In regards to a price, I can't spend too much. The upper limit would be 300€ for the monitor.
My primary use-case is gaming and video streaming. Although the video streaming usually happens on one of the other monitors while I game.
I appreciate all the help you can give me.
Iff you have less money: BenQ ZOWIE XL2411P 24.0" 1920x1080 144 Hz Monitor
If you have more money: Samsung LC27JG50QQNZA 27.0" 2560x1440 144 Hz Monitor
144Hz makes a big difference for gaming because it looks so smooth and nice.
PC: Ryzen 7 2700 | RX 5700 XT | Asus Prime B450-PLUS | CoolerMaster Masterwatt 600W | 32GB Corsair Vengeance 3200MHz RAM | 512GB NVME SSD & 7TB combined HDD | macOS Monterey 12.6.6, Windows 7 Ultimate x64 and WIndows 10 Pro x64
Laptop: MacBook Pro 15" 2015 | i7-4870HQ | R9 M370X | 16gb | 1tb SSD
iPhone 13 Pro Max | 256GB | iOS 15.7
My Folding Stats | #MuricaParrotGang
