Hello, I am new to the PC building game and was recommended this forum for help!
The Plan:
I am planning on building a PC with a possible budged of around 900$ to $1000 it's OK if your recommendation is a little more pricey that, but try not to go under the limit, that's fine too but I want a medium to high end PC. I want the PC to be able to play games like GTA 5, and Beam.NG Drive. Both games seeming to take a lot of power to run. And I would like to be able to run those games with high FPS.
Monitors:
I plan on running no more than two or three monitors, I would like DVI inputs on my PC and not HDMI as I would more likely use my monitors I already own which take DVI inputs. But if the PC has to have HDMI plugs that's fine with me.
Peripherals:
I am not going to buy and Peripherals with the budget, only PC parts.
Why am I upgrading:
I am Upgrading my PC because the one I use now, full of very old parts, will not run nearly any modern games at a decent fps, even at the lowest settings.
If you have any questions, ask away! Thanks for the help!
P.S. The images are the recommended requirements for the two games, I would like similar or better parts listed here. If it goes way over the budget let me know please, and thanks!
https://linustechtips.com/topic/1094866-first-time-pc-builder-help/
Hi!
Am a newbie to the forum myself and am planning my first build...
But I have researched a lot so will try helping.... Hopefully someone senior in this regard will pop up soon enough to guide you.
What parts are you planning to carry over...? From your existing pc I mean.
Also, any specific things you have in mind for the build, like themes or color etc? Or is pure performance what you are going for?
try with gaming monitor
PCPartPicker Part List
CPU: Intel Core i5-9400F 2.9 GHz 6-Core Processor  ($142.89 @ OutletPC)
Motherboard: ASRock B365M Pro4 Micro ATX LGA1151 Motherboard  ($78.89 @ OutletPC)
Memory: Team Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory  ($61.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($44.89 @ OutletPC)
Video Card: ASRock Radeon RX 5700 8 GB Video Card  ($329.99 @ Newegg)
Case: HEC HX300 ATX Mid Tower Case  ($36.98 @ Newegg)
Power Supply: Corsair CXM (2015) 450 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($54.89 @ OutletPC)
Monitor: LG 27GK750F-B 27.0" 1920x1080 240 Hz Monitor  ($299.00 @ B&H)
Total: $1049.42
Generated by PCPartPicker 2019-08-17 13:22 EDT-0400
