CABLE SPLITTING
Go to solution Solved by Fasauceome,
A single 8 pin provides 150 watts, you want to stretch that over double the connectors to make a 150 watt pinout provide 300 watts? That's asking for trouble.
The rule of thumb is that if your PSU doesn't have enough connectors for the job, it's just inadequate and you should consider a new one.
Also, what is the specific reason you want to go for dual GPU?
hi...i wanted to have a crossfire config for my HD7870...but my silverstone power supply only provides 2 x 8pin connector...question is, can i use a 8-pin splitter? so that from (2 x 8pin) + splitter = (2 x 8pin)(2 x 8pin)...hope I conveyed it correctly...will there be any performance issues or psu issues if i use that method?
Thanks,
https://linustechtips.com/topic/1094722-cable-splitting/
Thanks,
something like in the picture but im using 2 of them
https://linustechtips.com/topic/1094722-cable-splitting/#findComment-12813219
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1094722-cable-splitting/#findComment-12813229
well I was hoping to get better performance...and the looks...but since its gonna hurt my psu bad, I wont do it..ahahhaa..thanks for the quick replyy
https://linustechtips.com/topic/1094722-cable-splitting/#findComment-12813238
There are better ways to get good performance, an R9 280 or 280X isn't that expensive on the used market and would yield a decent performance bump. Consider even a 290X if possible
Also compare them to RX 470 and 570 prices
Edited by fasauceome
Primary PC:
PSU tier list
https://linustechtips.com/topic/1094722-cable-splitting/#findComment-12813248
ahh i see now...I only know nvidia line up and never amd...so im guessing its better to upgrade to R9 rather than having dual gpu which draws tons of power...thanks man..i appriciate it..
https://linustechtips.com/topic/1094722-cable-splitting/#findComment-12813258
