Help with VRM temps
Go to solution Solved by LukeSavenije,
and about the vrm part, a fan helps
Hello everyone , i have been having alot of frame drops and the only thing i can see are these temps on hwinfo VR VCC temperature are these vrms?
might this be causing the drops ? because everytime i get drops the temp on that raises by 1 or 2 and then jumps back down , normally it is at 66 idle when gaming it jumps from 66 to 67 ,68 degrees
if anyone can help me i would be very apreciated temps are on the image bellow , thank you
https://imgur.com/a/i0ixSGe
PC SPECS :
► CPU :
 i7 8700 k normally OCd at 4.5 ghz now i went to 4.0 to see if it made a diference it did not
►GPU: GTX 1080 8GB Non OC
 MB: ASUS Prime z370-p
 RAM: Gskill RIpjaws v 2500 MHz
 PSU: Thermaltake Berlin 80+ 630w
https://linustechtips.com/topic/1093200-help-with-vrm-temps/
Your temps are fine.  Tho it's odd that it rises 1-2 degrees only when under load. May want to remeasure that.
2500MHz RAM?  Did you mean 2400MHz?
Crank that 8700K up to high 4's or even 5GHz.  Your VRMs are fine and can handle it.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1093200-help-with-vrm-temps/#findComment-12801078
Yes I believe that to be your VRM's (VR). Those temps should still be fine. I used to have a B350M (AM4) board and the system wouldn't crash until my VRM's were hitting 77C.
The frame drops wouldn't have anything to do with your VRM temps. It can be caused by a number of different things. I would monitor your cpu and gpu utilization percentage. I used to have a Ryzen 7 1700 and while playing PUBG the chip would randomly downclock itself while under heavy load, causing a significant drop in frames.
Does the drop in frames happen to a number of different applications or only one?
Intel Core i7 9700F / Cooler Master 212 Evo / GeForce GTX 1660 SUPER / 16 GB G.SKILL RAM @ 2666MHz / GA-B365M-DS3H / EVGA 500w PSU
HP Pavilion Gaming 15 / Ryzen 5 4600H / GeForce GTX 1050 / 8 GB @ 3200MHz
https://linustechtips.com/topic/1093200-help-with-vrm-temps/#findComment-12801100
I havent really tested with aida64 i did it once for like 10 secs and my temps were almost at 80 c and i stoped it imediatly cause i was kinda scared i mostly use cinebench and my temps reach 70 c at 4.5 ghz , i will try to do it again with aida64 and comeback and tell you guys the results , and even when im browsing those temps keep going up and down from 64 c up to 67 , i dont know what else might be causing the drops but i feel like with this setup i should have good performance in games  but it just doesnt
https://linustechtips.com/topic/1093200-help-with-vrm-temps/#findComment-12801103
Thats the weird thing my cpu and gpu utilization never go above 50 mostly 36 cpu and max 40 gpu , cpu and gpu temps are also fine cpu never goes above 60c  it stays mostly at 47-55 c and gpu never goes above 46c that was the only thing i could see going up and down every 2 or 3 secs :/
https://linustechtips.com/topic/1093200-help-with-vrm-temps/#findComment-12801108
1 minute ago, IIGodlikemode said:
Thats the weird thing my cpu and gpu utilization never go above 50 mostly 36 cpu and max 40 gpu , cpu and gpu temps are also fine cpu never goes above 60c  it stays mostly at 47-55 c and gpu never goes above 46c also the clocks dont go down , that was the only thing i could see going up and down every 2 or 3 secs :/
https://linustechtips.com/topic/1093200-help-with-vrm-temps/#findComment-12801111
I had it at 2400 went to 2600 but it crashed my game and now im at 2555mhz  i think
https://linustechtips.com/topic/1093200-help-with-vrm-temps/#findComment-12801118
4 minutes ago, IIGodlikemode said:
I will try that but its gonna be tricky because my gpu sit right above the vrm heatsink maybe thats causing the temps to go up and down ?
not too much, i think it's also just because the prime p isn't that good of a vrm
but a fan should help a lot
https://linustechtips.com/topic/1093200-help-with-vrm-temps/#findComment-12801139
77c on VRM causes crashing?  That just sucks.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1093200-help-with-vrm-temps/#findComment-12801143
I  will try that then at the end of the month when the mulah comes xD and see if it helps , thank you very much for taking your time to help me im very apreciated :)
https://linustechtips.com/topic/1093200-help-with-vrm-temps/#findComment-12801146
no problem
and if you don't mind, we always appreciate some likes?
https://linustechtips.com/topic/1093200-help-with-vrm-temps/#findComment-12801151
3 hours ago, LukeSavenije said:
no problem
hehe done , i pushed my cpu to 4.8 ghz now the vrm temps are at 72 and cinebench my cpu gets up to 79 max mostly 72-74 c , when gaming it spikes up to 69 c are those temps safe ?
https://linustechtips.com/topic/1093200-help-with-vrm-temps/#findComment-12801722
yeah, that's fine
https://linustechtips.com/topic/1093200-help-with-vrm-temps/#findComment-12801724
nice , got a good boost of performance ive allways been kinda scared whenever my temps went above 60 xD now here i am at 79 max when stresstesting haha
once again thank you for your time :D
no problem
have fun though
https://linustechtips.com/topic/1093200-help-with-vrm-temps/#findComment-12801732
