Strix X470-F
1800x
1080 Ti
My right speaker will not work when plugged into my motherboard, no hardware changes or anything just suddenly stopped working. I have tried multiple speakers/headphones and they all have the same problem when plugged into the motherboard. Both speakers will work when plugged into the front case input though. Any ideas?
Thanks in advance
https://linustechtips.com/topic/1092688-mobo-speaker-jack-problem/
I would think that if the front works ok it must be a hardware problem with the jack. May be a broken jack. Double check the plug is fully inserted.
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
You should be able to reassign the output to a different port. Try that.
I had heard it wasn't in the control panel in some of the latest driver versions.
See if you have and can open
"C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe"
