Hi!
i think that if you Plug the device into a PC then go to itunes, You could be able to sync and restore without a Password.
You then get a choice to restore or set up again. (I think)
Good luck,
Jake
GPU: RTX 3060Ti 8GB
CPU: Ryzen 5 3600
RAM: 32GB DDR4 3200MHz
Mobo: B450M-K
Keyboard: Logitech G915
Mouse: Logitch G502 HERO Lightspeed
Audio: BeyerDynamic Tygr 300R
https://linustechtips.com/topic/1091962-iphone-help/#findComment-12791970
