So i just bought an NES online, and the listing neglected to inform me that it was a french version. So the different voltage rating aside (i have converters) I got this cable for the video out...
As you may be able to tell, that is no RGB RCA output, and i only have an RCA HDTV that has the bells and whistles, like HDMI and VGA. However. There is no way in hell that will go into the back of my TV. I've done some research and found this is a Scart cable. However the other end looks just like the one that would go into your regular old Wii console/N64/GameCube, Correct? So would i be able to just go and use the N64 to RCA cable i have? Or will this cause damage? Or what? I really want to play with this console, to make sure it works and all, but i'm a little stuck...
Also is there something like a Scart end to RCA?
Thanks!
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
https://linustechtips.com/topic/108913-nes-issues/
31543-Robin-Williams-what-year-is-it-TaC
https://linustechtips.com/topic/108913-nes-issues/#findComment-1455654
I died. I truly died.
https://linustechtips.com/topic/108913-nes-issues/#findComment-1455658
https://linustechtips.com/topic/108913-nes-issues/#findComment-1455676
