Amd ryzen master problem with memory control SOLVED
Go to solution Solved by anto1520,
i fix it, taking out the ram and put it back
1 minute ago, anto1520 said:
i activate the memory control on the amd ryzen master and this happend
Go into BIOS and turn it off, or Safe Mode, depending on where you activated it
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
12 minutes ago, anto1520 said:
well, now who i delete a post here?
The mods would delete it if need be, but you can just mark your own topic as solved with the check mark on your post
Primary PC:
PSU tier list
How many watts do I need?
