1 minute ago, MikeMagee02 said:
How?
You put the waterblock on then put the backplate back on, easy. I used the stock backplate on my Vega FE when I put a Heatkiller IV block on it, didn't want to buy a new backplate.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1087390-gpu-water-block-ekwb/#findComment-12759586
Lol, you’re gonna need to be a bit more detailed than that.
Screws arent even close to the same size. And you have to use stock screws in order to put the back plate on. Unless you want to drill out holes and hope for the best.
https://linustechtips.com/topic/1087390-gpu-water-block-ekwb/#findComment-12759648
Check the manual of EK:  https://www.ekwb.com/shop/EK-IM/EK-IM-3831109831502.pdf
In short, they are selective in the screws they use for the cool block and back plate.
Also see:
AMD 5900x, 2x16GB ( G.skill F4-3600C16 ), Radeon VII, Radeon 570,  Corsair 1200i , SSD 240/500GB, HDD 640GB,1TB,5TB, 1TB NVME. Lian li 011Dyanmic XL, big ass LTT mouse-pad & stealth water bottle
https://linustechtips.com/topic/1087390-gpu-water-block-ekwb/#findComment-12760416
Doesn't help as it isn't an fe card. Completely different designs.
https://linustechtips.com/topic/1087390-gpu-water-block-ekwb/#findComment-12760425
How much bigger are the fe screws compared to the ek screws?
https://linustechtips.com/topic/1087390-gpu-water-block-ekwb/#findComment-12761092
Think the ek are bigger. Either way you won’t be able to screw it down as the tiny screws won’t be able to go into the ek screws. I’d just wait and get an ek plate as they are very cheap with the be obsolete cards.
https://linustechtips.com/topic/1087390-gpu-water-block-ekwb/#findComment-12764185
