I am new to PC building and was wondering does the fan controller on cases that come with one on the front panel use seperate headers from the motherboard. If it depends on what case this is what I purchased. https://www.coolermaster.com/catalog/cases/mid-tower/masterbox-5t/
Asking as I want to put more case fans into it and was wondering whether or not I need to get a hub as my motherboard has 4 useable headers for case fans (-1 for cpu and +1 for AIO header)
https://linustechtips.com/topic/1087389-fan-headers/
I'm new to pc building and was wondering are the connections for fan controllers built into a case there own seperate headers or would they still connect to the motherboard fan headers separately
Case:https://www.coolermaster.com/catalog/cases/mid-tower/masterbox-5t/
Motherboard:https://www.asus.com/Motherboards/PRIME-B450-PLUS/
https://linustechtips.com/topic/1087389-fan-headers/#findComment-12756236
I don't see that many headers on your mobo
It's best to go via header to have control
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1087389-fan-headers/#findComment-12756291
What fans are you using?
The case fan controller uses power from the psu and delivers 7v (low) or 12v (high) for approximately 60% and 100% rpm respectively.
https://linustechtips.com/topic/1087389-fan-headers/#findComment-12757352
