I have recently Built a new systems and seeing high temps at stock.
Specs
I9 9900K
Aorus Master z390
3000Mhz Corsair Platinum
Asus OC 2080ti
H150i AIO
Case Phantom 630
I have set it all up did my first stress test with ROGbench after 30min I was at 90c on the CPU stock settings
Next day I re seated the AIO and replace the paste with MX4 re seated and got 88c
I started to undervolt now
XMP Enabled
MultiCore Enhancement Enabled
Vcore 1.14
Load Line Turbo
Temps now
Adia64 72c
ROGBench 76c
Case Layout
Intake 2x140mm 1x200mm Filtered
Exhaust 1x120mm 380mm Radiator Non Filtered
https://linustechtips.com/topic/1087074-9900k-build-temps/
90C at stock on a 9900k is completely normal. It is a cpu that runs VERY hot.
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
https://linustechtips.com/topic/1087074-9900k-build-temps/#findComment-12754111
I had a custom loop with a 360 and a 240 for the 990K - I had to add another 360 because I wasn't happy with the temps. (I wanted it basically silent)
9900K  / Asus Maximus Formula XI / 32Gb G.Skill RGB 4266mHz / 2TB Samsung 970 Evo Plus & 1TB Samsung 970 Evo / EVGA 3090 FTW3.
2 loops : XSPC EX240 + 2x RX360 (CPU + VRMs) / EK Supremacy Evo & RX480 + RX360 (GPU) / Optimus W/B. 2 x D5 pumps / EK Res
8x NF-A2x25s, 14 NF-F12s and a Corsair IQ 140 case fan / CM HAF Stacker 945 / Corsair AX 860i
LG 38GL950G & Asus ROG Swift PG278Q / Duckyshine 6 YOTR / Logitech G502 / Thrustmaster Warthog & TPR / Blue Yeti / Sennheiser HD599SE / Astro A40s
Valve Index, Knuckles & 2x Lighthouse V2
https://linustechtips.com/topic/1087074-9900k-build-temps/#findComment-12754235
20 minutes ago, APasz said:
Do you have a custom loop or are you using that H150i?
If you have custom loop, what thickness are the radiators? And is the gfx card also in the loop?
If you are using the H150i for the cpu, those are good temps.
I am just using a H150i
It currently holding at 76c during 3 hours in an ROGBench stress test but the coolant is hitting 49c
https://linustechtips.com/topic/1087074-9900k-build-temps/#findComment-12754343
  • 4 months later...
I have a i9 9900K too and with my BeQuiet silent loop 360 it's gotten about 82 degrees after 90 minutes of Aida64s stresstest. With the radiator@ 60% fan speed and the case fans on silent mode. I'm pretty pleased with that tbh. I concidered delidding but in a video of "Der 8auer" I saw that the benefit doesn't justify the risk. He got the temps about 6-8 degrees lower by replacing the standard compound with liquid metal and another 2 degrees by placing the cooler directly on the die. But since the 9900K heat spreader is soldered it's quiet risky delidding it...
I will maybe consider undervolting though. Thanks for the data you shared ?
CPU: AMD Ryzen 7 7800 X3D | Motherboard: MSI MPG X670E Carbon WiFi
RAM: G.Skill Trident Z5 6000 MHz CL30 2x16GB | GPU: AMD XFX 7900 XTX
Case: BeQuiet Dark Base 900 Pro rev.2 | PSU: BeQuiet Straight Power 11 1000W
Storage: Samsung 990 Pro + Samsung 970 Evo+ 1TBGB M.2 + Samsung 970 Evo 1TB M.2 + Seagate Ironwolf 8TB HDD
Watercooling: EKWM Quantum Velocity2 + Alphacool Aurora D5 + Alphacool GPU Block
Radiators & Fans: 420/30 copper rad + 360/30 copper rad all Silent Wings 4 Pro @ 40%
Keyboard: Corsair K95 Platinum RGB | Mouse: Logitech G502X Plus | Mousepad: Logitech Powerplay | Headset: Corsair Virtuoso XT
Monitor: Samsung Odyssey G9 49" 32:9 1440p
https://linustechtips.com/topic/1087074-9900k-build-temps/#findComment-13106894
