Hi guys.
I have an ASUS ROG GL752VW and it's totally overheating
Specs:
i7-6700HQ
GTX 960M 4GB
8GB RAM
IDLE:  CPU: 60°C
          GPU: 70°C
IN GAME: CPU 88°C
                GPU 88-90°C
How I can make it stay at smaller temperatures?
*I play on a wooden table* not in bed
https://linustechtips.com/topic/1086379-overheating/
For a laptop those are normal(ish) temperatures unfortunately. If you've had the laptop for a few years I'd recommend opening it up and using some compressed air to blow out the dust.
Other solutions that may help:
  • Undervolting
  • Changing thermal paste
  • Laptop cooling dock?
  • Aggressive fan curve
~Air Cooling Advocate~
https://linustechtips.com/topic/1086379-overheating/#findComment-12749551
  • Undervolting
When im playing I don't hear the fan as loud as it was like it was when I bought it so it might need a good cleaning
Thanks for your answer!
https://linustechtips.com/topic/1086379-overheating/#findComment-12749562
