ITX 4 Pin?
Go to solution Solved by Denned,
There's a 8 pin CPU cable on your PSU. It can normally be split into two cables.
What do you plug into the 4 Pin connector on ITX motherboard? I'm confused, do you just plug in your 8 pin or use a 4 pin that you would use for like a video card or something.
Intel i5 3570K || Gigabyte GeForce GTX 1070 8GB FE || 8GB Crucial Ballistix Sport 1600MHz || ASRock Z77 Pro 3 || WD Caviar Blue 1TB || Noctua NH-U12S || Creative Sound Blaster Audigy FX Sound Card || Fractal Define R4 || Gigabyte GC-WB867D-I REV 4.2 Wireless Network Card
ASUS VC239H Monitor || Corsair Strafe Cherry MX Red || Logitech G Pro || Philips SHP9500 w/ V-MODA BoomPro Mic || Reflex Lab Pro 36 Heavy Mouse Pad || Google Nexus 6P 128GB
https://linustechtips.com/topic/108627-itx-4-pin/
There are cables JUST FOR the CPU powered, there is a 4 pin and sometimes 4+8 pin, that 8 pin is not a PCI-e power plug. It is just for the motherboard. And depending on the motherboard, you will either use the 8-pin or just the 4-pin alone. Then the 8-pin wouldn't be used at all.
https://linustechtips.com/topic/108627-itx-4-pin/#findComment-1452014
depends which 4-pin..
I'm saying on a motherboard such as mine Gigabyte Z87N-WIFI where there is only 24 pin and 4 pin because it is ITX.
https://linustechtips.com/topic/108627-itx-4-pin/#findComment-1452023
and if it can't?
https://linustechtips.com/topic/108627-itx-4-pin/#findComment-1452057
it doesn't need to be split just plug it in anyway it can only go one way, provided it is the CPU cable.
ty
https://linustechtips.com/topic/108627-itx-4-pin/#findComment-1452078
there is no 4+8 pin.....
but yea the 4 pin is for the CPU.
https://linustechtips.com/topic/108627-itx-4-pin/#findComment-1452082
