I've had this pc with an 8700k running 4.4ghz all core 1.25v for about a year, but other than those two settings every thing else was on auto and it was throttling the CPU under heavy load to keep the processor at the 95w TDP.  I unlocked all those settings in ASUS bios and only those settings, turned off intel speedstep, SVID control, rebooted and ran realbench stress test.  Temps were fine but it crashed at the 10 minute mark.  I had saved the out of the box profile so I loaded that up and rant the test again with the same crash at the same 10m mark.  Can I safely assume it's the program and not this really low clock speed/voltage? Just want to be sure.
Thank you.
https://linustechtips.com/topic/1086073-question-for-realbench-users/
