So i am lil bit confused.In my area , The prices of gpu are higher than usual.And there are also not much variety.
I have three options: (Every GPU is used)
1) RX560 4gb Sapphire pulse(1024 S.U) for (130$)
2)GTX960 2gb Zotac (120$)
3)MSI twin frozer GTX660(For 90$)
Also Please consider my specs:
Core 2 quad Q9650
6gb ram
(If i go for a GTX660 then i will have money to upgrade my pc)
Please suggest
https://linustechtips.com/topic/1085905-help-me-choosing-my-gpu/
Of those the GTX 960 is the best performer, it also so happens it's about the hard limit that CPU can handle before there's no performance increase
What's your current GPU?
Primary PC:
PSU tier list
How many watts do I need?
Just now, Sumolizer said:
I am currently using a GTX650
Then the 660 probably wouldn't be worth considering, small jump in performance.
Also, you can hopefully sell that GPU for a good price and start saving for a new CPU
Primary PC:
PSU tier list
actually included the price.
So you mean i should go for a GTX960?
But will its 2gb vram limit performance?
2GB is pretty fine for what the 960 was made for, 1080p medium details
Primary PC:
PSU tier list
3 minutes ago, Sumolizer said:
Just asking
Will a RX560 4gb be bottlenecked by a Q9650?
The 560 and the 960 are both pretty bottlenecked, but the 960 is very comparable to the 560 (if not better performance) and cheaper so go with that.
Primary PC:
PSU tier list
I'm using a GTX 960 (2GB) right now and most games run fine using medium to high settings. It has trouble running Doom (2016) but games such as Overwatch, Borderlands 2, Rocket League, Tomb Raider and the like run fine for me. Check this video out.
