Hi there,
So i tried overclocking my 2133 ram to 2400 i have 4(4x4) sticks but for some reason i can only control the timings of a and b and when i do only two out of the four are overclocked to 2400 and yes the system sees all the ram 16gb but it thinks its prob just 2 sticks in a single channel so if you have suggestions or advice or more things to try and help me pls ask :)
mobo: gigabyte z270 gaming k3
ram:ddr4 hyper x kingston fury 4x4 2133
https://linustechtips.com/topic/1084996-need-help-with-overclocking-ram/
Just now, LukeSavenije said:
so it gets more current and you might be able to go to 2400 or even higher?
i did raise it and it works just fine its just that i can change only two of the 4 sticks timings a and b are the only ones i can change
isn't that per channel then? normally a and b are indications of channels
i mean thats what i thought but i saw another guy with 4 sticks and he had all 4 of them showing in the same bios when i do try overclocking i have 2 on 2133 and the other 2 on 2400 Xd
hm... odd
7 minutes ago, starcoaster said:
A and B are channels
memory slots are regarded as
A1
A2
B1
B2
you're adjusting the channel timings, not the timings for each individual DIMM
some BIOS' have a mode where you can view the SPD information of each individual DIMM and that may be the case for yours, but for literally every single bios i have used, memory clocks and timings have been done on a per-channel basis
Thanks maybe i just forgot to edit one of channel tho it should do it auto but now it works thanks anyway
