1 minute ago, vito1998z said:
Hi, I have just recently flashed my UEFI to solve the usable ram issue. But after I flashed it, now Windows only detects 6GB of RAM, while in the UEFI settings is shows 8GB (2x4GB). What should be done in order to fix this? Please help!
full system specs please....
If someone has helped you out on the forum don't forget to give them a reaction to say thank you!
The only true wisdom is in knowing you know nothing. - Socrates
Please put as much effort into your question as you expect me to put into answering it.
https://linustechtips.com/topic/1084687-ram-problem/#findComment-12736873
2 minutes ago, Sakkura said:
Are you perhaps using integrated graphics? That will take some of the RAM for itself.
This is exactly why I asked for the specs
https://linustechtips.com/topic/1084687-ram-problem/#findComment-12736903
Ryzen 3 2200g
8GB RAM (2x4)
Vega 8 Integrated Graphics
Asrock A320M-HDV R4.0
Yes, I use integrated graphics. I tried to change the iGPU VRAM settings via UEFI Setting, but It didn't work. That's why I flashed the UEFI.
https://linustechtips.com/topic/1084687-ram-problem/#findComment-12736920
