Posted July 20, 2019 so I have read a review on a site which suggest the wraith prism is better than the max. problem is the max has a tdp rating of 140 vs 105 for the prism. what I am wondering is why someone reviewing both coolers would even suggest such a difference. I mean 105 tdp chips are common from amd so why wouldn't the max be the better cooler outside of the fan control on the prism? I am a bit confused there. Link to comment https://linustechtips.com/topic/1084559-differences-between-wraith-max-and-wraith-prism/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 20, 2019 7 minutes ago, ralphandmike said: so I have read a review on a site which suggest the wraith prism is better than the max. problem is the max has a tdp rating of 140 vs 105 for the prism. what I am wondering is why someone reviewing both coolers would even suggest such a difference. I mean 105 tdp chips are common from amd so why wouldn't the max be the better cooler outside of the fan control on the prism? I am a bit confused there. im not to sure about the technical stuff but the wraith have had alot of great stuff said about it in terms of handling heat very well on their chips from 3rd party people. Link to comment https://linustechtips.com/topic/1084559-differences-between-wraith-max-and-wraith-prism/#findComment-12735807 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 20, 2019 Author 1 minute ago, Norwegiantweaker said: im not to sure about the technical stuff but the wraith have had alot of great stuff said about it in terms of handling heat very well on their chips from 3rd party people. yeah that is true. they are similar in design to the noctua and be quiet dark rock series coolers. actually they are more closer to the old Rosewill RCX-Z1 - Long Life Ball Bearing CPU Cooler / 92 mm Silent Cooler with Aluminum Heat Sink. those are good for some cpu designs Link to comment https://linustechtips.com/topic/1084559-differences-between-wraith-max-and-wraith-prism/#findComment-12735821 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 25, 2019 There seems to be different tdp ratings for the Wraith Prism depending on where you look. Some state the same 140w tdp. At the end of the day, the spec doesn't affect the actual performance. The two coolers are pretty similar but the Wraith Prism being a bit taller does seem a bit better. https://segmentnext.com/2018/05/07/amd-wraith-prism-max/ If you ever need help with a build, read the following before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/Also, make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them. Link to comment https://linustechtips.com/topic/1084559-differences-between-wraith-max-and-wraith-prism/#findComment-12747671 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 11, 2020 On 7/25/2019 at 5:21 AM, WoodenMarker said: There seems to be different tdp ratings for the Wraith Prism depending on where you look. Some state the same 140w tdp. At the end of the day, the spec doesn't affect the actual performance. The two coolers are pretty similar but the Wraith Prism being a bit taller does seem a bit better. https://segmentnext.com/2018/05/07/amd-wraith-prism-max/ If anything that review would suggest that the Max is better unless you have the Prism on full speed no? I have a prism in my setup (R5 3600) and i wouldn't like to think how loud it gets with CPU under full load.. Link to comment https://linustechtips.com/topic/1084559-differences-between-wraith-max-and-wraith-prism/#findComment-13588329 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
