Hey guys i'm looking into upgrading from 2 titans to 2 780ti's and i was looking at the Evga classified and at the gpu block for it. 1. Can i remove that Evga logo? (Is it a sticker?) 2. Are these high performance (the blocks)? 3. Is there another bettr block for the evga classified?
Thanks.
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
https://linustechtips.com/topic/108441-i-need-help-with-my-gpu-blocks/
Do you already have the Titans? Because I wouldn't recommend switching. You'll see nearly no difference...
Case: Lian Li PC011-D - CPU: 3900x - GPU: 2080ti Reference - Mobo: Gigabyte - Ram: Corsair 4x16gb 3200MHz - SSD: 2TB Samsung Evo NVME
