Audio problems on games and discord
TeoPap
Hello .
Recently i had upgraded my system with a b360 f gaming and an i5 8500 and from this day im having issues with the pc audio . I reinstalled all drivers , format 2 times the pc , sent the mobo back to the store i bought for service ( took 3 weeks and the service didnt find any problem with the audio )
So the problem is like this :  While gaming and talking to discord , every like 15 mins the sound crashes , i searched it in reddit and i saw that some people say that discord messes with their pc sound.
BUT while gaming without discord opened i get no crashes
And the second problem is that some games have sound and some not
try these (not at same time)
turn off discords overlay...
in voice/audio setting turn on or off openh264 (this turns off or on hardware acceleration)
try setting discord as admin
just a few off the top of my head
Did you just replace components or reinstall Windows clean too? If you just replace components, problems like this tend to happen.
Tried those settings , to be honest i can see its fixed for now , hope it gets fixed for ever
You mean in the upgrade ? yes i changed the mobo . and yes i did a clean windows install
