Try and update Windows. A couple updates ago this happened to me, Task manager was telling me a few ridiculous things and not the correct RAM speeds. An update a couple days later solved the issue
Intel Core i7 9700F / Cooler Master 212 Evo / GeForce GTX 1660 SUPER / 16 GB G.SKILL RAM @ 2666MHz / GA-B365M-DS3H / EVGA 500w PSU
HP Pavilion Gaming 15 / Ryzen 5 4600H / GeForce GTX 1050 / 8 GB @ 3200MHz
https://linustechtips.com/topic/1083737-need-help/#findComment-12729521
Just now, TechyBen said:
Not if it has nothing to do with pagefiles.
Yes but Idk what he uses his pc for.. maybe 50 tabs with ltt content? :D
To be honest I dont now "much" about pagefiling but these are the only two things that are "possibly the error". Or he just created a RAM Disk unintentionaly.?
https://linustechtips.com/topic/1083737-need-help/#findComment-12729523
An update is the best thing I can think of especially when 8.1GB is reserved for hardware. The OP should manually seek out update 1903 if it isn't automatically available. 1809 had lots of problems.
https://linustechtips.com/topic/1083737-need-help/#findComment-12729671
