So I’m pretty new to overclocking and just recently decided to try it out. Now I know roughly what temps not to cross over. However I was wondering I overclocked my I7 8700K to 4.7ghz, voltage at 1.25 I believe and ran AIDA64 for about 40 min. The cpu core temp seems stable at 68C with the max having been 73C. All the individual cores are 63-69C each with one reaching 78C once. Would you say this is reasonable or should I try adjusting any to get a little lower temps?
https://linustechtips.com/topic/1082947-cpu-stress-test-temps/
You are fine.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1082947-cpu-stress-test-temps/#findComment-12723921
