Hey guys, I need help. I’m considering upgrading my laptop by adding an 8gb ram, but I’m not sure if this is a RAM slot or not. If so, is this a DDR4 or DDR3? My laptop specs said that this runs a DDR4 2400 memory. For the upgrade should I get the exact DDR4 2400, or can I go for higher clock speed? Thanks!
https://linustechtips.com/topic/1082895-i-need-help/
Yes, that is the RAM slot and yes, DDR4 is what you want. Best is to match what you have already.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1082895-i-need-help/#findComment-12723579
