Graphics Card Block Leaking
If its anything like normal EKWB blocks, it wont void your 'normal' warranty however it will void leak protection warranty.
See below
https://www.ekwb.com/blog/did-you-know-that-you-can-open-your-blocks-without-voiding-warranty/
In other words so long as you dont OPEN the block and break the seal, tightening the screws only wont void the warranty. if you decide to open it however, and break the sticker/seal it will void future leak protection warranty.
Removing the block from the GPU also will not void you warranty.
EKWB is generally very good when it comes to their warranties as they are fully aware of how their products are used.
That said. The card is a MSi seahawk, so its MSi you would be dealing with, so long as there are no stickers or seals preventing you from removing the block form the card, it will not void warranty.
As for links to work off, no, however the scews and allenhead bolts used to tighten down the block should be accessible without the need to remove the block entirely. Just tighten down the ones you can get to and hopefully that will work. I dont know how the seahawk decal on the front is applied to the block, hopefully its removable without damaging it as it looks like it will be covering a bunch of the bolt/screws that you would need access to,to tighten them up a bit.
