First PC Build Help
Go to solution Solved by OmicronEta,
This is a fine build. The only real recommendation I would have is to get the Ryzen 5 2400G as it is only a couple bucks more at this time. I have one and after I added a used rx580 in the system it ran beautifully. Those cores do help sometimes, especially if you do plan on working lightly. Also going from Vega 8 to Vega 11 might be a bit more enjoyable till you get the gpu.
Hi,
Finally got all my parts ready for my budget first PC build. I know some parts could be upgraded, I am adding more ram, a GPU and more fans in the future. But for now, I'm happy with all the parts. But could someone please just double check the parts list and see whether there all compatible/will fit. (+Also please let me know if I'm missing anything) THANKS!! (I'm not interested in upgrading the parts I just would like to know whether they will work, thanks ?)
https://uk.pcpartpicker.com/user/BobThePCBuilder25/saved/#view=BTCZf7
https://linustechtips.com/topic/1081975-first-pc-build-help/
Yes they are compatible, pcpp says so in the website
Aside from a GPU ur not missing anything, tho it's obviously an Apu system. Also, if possible, get a different Mobo, maybe an ASRock b450m pro4, iirc d3sh is bad
I lurk
HP Spectre x360 13t late 2019
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Razer Blackwidow Lite
Steelseries Rival 3
https://linustechtips.com/topic/1081975-first-pc-build-help/#findComment-12716870
Edited by OmicronEta
Addition
Home Base : Ryzen 5 2400G - ASROCK HDV R4.0 B450M -  Corsair Vengance Pro RGB 2x8GB @3200Mhz - Sapphire Pulse RX 5700XT - WB Black (2018) 500GB NVME SSD - 250GB WD (P.O.S.) HDD - 250GB LITEONIT SSD - Cougar MX330 ATX Tower - EVGA SuperNOVA 750 GQ 750W Gold- Razer Deathaddder Elite - Corsair K55 RGB Keyboard
https://linustechtips.com/topic/1081975-first-pc-build-help/#findComment-12716874
