Hi, i would appreciate a lot if you could help me in building a hackintosh. I have installed OSX Yosemite on an old computer earlier (i.e. "long time ago/once upon a time").
I have a secondary PC which is just lying on the desk and collecting dust. And so, i would like to try my hands on in buiding a Hackintosh.
My secondary PC Specs are:
ASUS X79-Deluxe
Intel i7 4930K
nVidia GeForce GTX 1070
G.Skill 4x4GB RAM
Crucial MX300 275GB SSD and so on...
Previously i have tried "tonymacx86.com" "insanelymac.com" and "hackintoshzone.com"
but now i am confused as to which would be the best and ideal build for the above PC specs.
NOTE: I don't own/run any Vitual Machine.
But i just want to Install "macOS Mojave" on the secondary PC (if it is all POSSIBLE).
And, there are lots of sites to choose from... like....
https://www.hackintosh.com
https://www.tonymacx86.com
https://www.insanelymac.com
https://www.osx86project.org
https://www.hackintoshzone.com
https://www.osx86.net
https://www.macbreaker.com
https://osxlatitude.com
https://9to5mac.com
And so, which one would you recommend for my BUILD. Thank You.
Just Wanted to Try out FCPX.
https://linustechtips.com/topic/1081918-help-me-build-a-hackintosh/
Google "your motherboard model + mojave + success"
i found this :
https://www.tonymacx86.com/threads/success-os-x-10-14-2-mojave-i7-3930k-asus-sabertooth-x79-gtx680-directcu-ii-oc-16gb-ram.104284/
There's no one size fits all method in building hackintosh, everything is trial and error.
hackintosh today is not that difficult as in the early days.
You could do a vanilla install or install a distro such as niresh which is relatively easier.
https://www.hackintoshzone.com/files/file/1069-niresh-mojave/
