Does anyone have any idea where i can find any sort of "bridge Input port" ? can i DIY one?cause i looked everywhere and nothing Except HDplex and i'm pretty sure they can only carry 300w . the only one is Digital storm but no luck anywhere Thanks everyone
https://linustechtips.com/topic/1079120-help/
2 minutes ago, Stragixz said:
Does anyone has know where i can find any sort of "bridge Input port" or DIY one cause i looked everywhere and nothing Except HDplex and i'm pretty sure they can only carry 300w . the only one is Digital storm but no luck anywhere Thanks everyone
That would be a fully custom part for HD Plex's linear power supplies. Unless you are using one there isn't a need for it, if you wanted to make one you can get PCI-E pined connectors and to have a custom PCB made to make the bridge.
https://linustechtips.com/topic/1079120-help/#findComment-12695565
