So I have a computer with two graphics cards and realized an issue with heat in theory. Graphics cards fans pull air up and to the side. This leads to heat build up on the back of the card, especially if you have a second card above it. Why do they not add a few holes through the pcb and have some air flow through and pull heat out in the direction dictated by physics as it would be cheaper energy wise?
Desktop: CPU: AMD Ryzen 9 3950x  | Motherboard: B450 Tomahawk | RAM: G.Skill Trident Z Neo Series 32GB @ 3600 MHz | GPU: EVGA GeForce RTX 3080 Ti FTW3 | Case: Phanteks Enthoo (black) | Storage: 512GB Adata SU800 SSD + 1TB Sabrent M.2 + 8TB Seagate External HDD | PSU: EVGA Supernova G2 850W | Monitor: LG 27GN950-B
https://linustechtips.com/topic/1079093-graphic-card-design-question/
That's what blower coolers exists for when you can't afford waterblocks.
Personal Desktop":
Luna, the temporary Desktop:
The Sapphire vega 56 has kind of a neat design that I don't see too often but kind of along the lines of what you describe.
Ryzen 2600 - Sapphire Pulse Vega 56 - Corsair Vengeance LED DDR4 3000 C15 2x8GB - Corsair Force MP500 NVMe PCIe M.2 240GB - 2x Seagate Barracuda 2TB -
AsRock B450 PRO4 - Deepcool Earlkase Case -  Seasonic Foucus+ 650
