i recently got my self a 144 z 1920x1080 LCD display.I have set it up and then when i went into the nvidea control panel to set the refresh rate from 60hz to 144hz my screen went blurry.Can someone help mr fix it?I havea gtx 1060 3 gb and i have a standard DVI cable,my mopnitor is a acer KG251Q same thing happens when i set it to antrhing above 69hz.pls help
https://linustechtips.com/topic/1079000-refresh-rate-help/
Did you update the drivers for your GPU and everything before trying?
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1079000-refresh-rate-help/#findComment-12694661
