Suddenly, my PC stopped turning on other than for for half a second. I discovered that my old Antec PSU was the problem and replaced it. Now it actually turns on and I can see the POST screen, but thats it. I can't enter the bios or boot menu or anything else. I can only see the POST message which ends with the RAM size and then it just stops there. When I press F8 or any other button it shows that it was pressed but doesn't enter another screen or menu.
Specs:
Xeon x3470
8gb 1333mhz DDR3
Asus p7h55-m pro
Zotac 1050 Ti
And a USB 3.0 card that I tried to remove but still gave the same problem.
Edit: I tried to play around with the RAM sticks and tried to reset CMOS but neither worked.
Edited by Shipwreck5
https://linustechtips.com/topic/1078934-stuck-at-post/
