Hey guys i'm building a computer for my friend i got everything figured out except I cant figure out which is better the GIGABYTE GA-Z77X-UD4H and the MSI Z77A-GD55. It has to be one of these boards really no other options.  I appreciate any input thanks guys.
https://linustechtips.com/topic/10788-motherboard-choice-help/
Both are really good boards. You can't go wrong.
CPU: Intel i7 4790k Motherboard: ASUS Maximus VII Formula RAM: Corsair Vengeance Pro 32GB 2400MHz: GPU: 2x EVGA GTX 780 Ti's with ACX cooling PSU: Corsair AX1200 Watt Gold SSD: SanDisk Extreme 120GB SSD (Operating System) SSD: Mushkin Chronos 240GB (Games) Sound card: Creative Sound Blaster ZxR HDD: Seagate 3TB External OS: Microsoft Windows 8.1 Mouse: Logitech G502 Gaming mouse Keyboard: Corsair Vengeance K60 MX Red switches Monitor: ASUS VG248QE 144Hz
https://linustechtips.com/topic/10788-motherboard-choice-help/#findComment-115267
The reasoning it has to be 1 of those is to go along with what i'm planning for the build. Unless there's a similarly designed board that is better that i'm missing. i'm still leaning more towards the Gigabyte but something in me is saying get the MSI.
https://linustechtips.com/topic/10788-motherboard-choice-help/#findComment-115272
they're both pretty cracking boards, just go for the one that you find aesthetically the most pleasing ;)
I personally really like my gd65 which has similar or the same aesthetics.
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/10788-motherboard-choice-help/#findComment-115288
which do you guys think go nicest with black sleeved cables a msi hawk 7870( possible crossfire) and dominator platniums?
I would go with the GIGABYTE GA-Z77X-UD4H if you want it to match your black sleeved cables.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/10788-motherboard-choice-help/#findComment-115402
