hello i’m just panning i’m purchasing a new graphics card and was thinking of getting the 1660 ti, need help knowing if it’s worth it or not. if it is feel free to suggest specific models, also i’m planning to buy it in another country, would i have any trouble bringing it back on plane?
https://linustechtips.com/topic/1078744-need-help-in-choosing-gpu/
There shouldn't be a problem as long as you keep it in the static free bag. And as long as you can deal with customs.
The 1660ti is in a questionable place right now. What display do you have? What's the budget? I think you won't be able to truly know until 2060 super hits the shops, lowering the price of the 2060 and the 1660ti, accordingly.
I once gave Luke and Linus pizza.
Proud member of the ITX club.
**SCRAPYARD WARS!!!!**
#BringBackLuke
It depends if you're gettin the top end one that's about $310 or not; if so, then just pay $40ish more and get a RTX 2060, which's roughly a GTX 1070 TI in performance.
Otherwise, it's a nice card for low-low/mid level gamin in 1080p.
Primary
OS:        Windows 10 - Professional (64-bit)
CPU:      i9-10900k 3.7-5.3GHz (10th gen)
GPU:      EVGA RTX 3080ti FTW3 Ultra Gaming 12gb
MB:         ASUS RoG Maximus XIII Hero (ATX)
RAM:      64gb (4x16) DDR4-3200MHz G.Skill TridentZ Silver/Black (CL16)
HD:         1x 8TB Corsair MP400 NVMe PCIe 3.0 (SSD)
               2x 16TB Seagate Exos 7200rpm (HDD)
E-HD:     12TB WD
PSU:       EVGA 1000w G2, 80+ Gold (modular)
UPS:       900w CyberPower
Display:   ASUS 27” 1440p/270Hz IPS 0.5ms (XG27AQM)
                Aorus 27" 1440p/165Hz IPS 1ms (FI27Q-P) iGPU
KeyB:      EVGA Z15 (wired)
Mouse:    Logitech G-502 Hero (400/600/800/1000)
Headset: JBL Quantum ONE Gaming Headset
Case:      Cooler Master MasterCase H500P Mesh (ATX)
Other:     XB-1 Wireless Controller Adapter w/Controller
              NPET H01 Gaming Mouse Bungee Cord Holder w/4 USB Ports
Gaming Computer Specs.pdf
