I recently picked up a super cheap core2 duo laptop for couch-side browsing and youtube content, that will have 4 GB of RAM and a u7300 (2 cores). In the past I've installed Mint/Cinnamon on VMs with 2 cores and about the same RAM, but never tried it on bare metal.  Would i be better off using Lubuntu/Linux Lite/ Xubuntu etc. or will Mint be ok on this system?  Would XFCE or another desktop work better than Cinnamon?
Thanks!
https://linustechtips.com/topic/1078741-mint-system-requirements/
2 minutes ago, SafyreLyons-5LT said:
Mint should do more than fine, I tested it with similar specs. I would however keep a backup plan of Lubuntu, that is a general rule of Linux. Always have a backup plan. General rule of life to be honest.
I got backups for backups.  I hear ya.
This machine should never have anything important on it, so files aren't the issue.  It's more the peppiness of the system I'm worried about running all the Cinnamon bling.
Actually, as I wrote that I just realized - I could install Mint, like it and keep it or delete it and install something else if I want.  It's a $20 machine.  No risk.
On 7/4/2019 at 8:53 PM, Lenovo1984 said:
I would personally go with Mint and the MATE desktop. It works well for me on specs like that.
On 7/4/2019 at 9:05 PM, SafyreLyons-5LT said:
Cinnamon isn't bad. Mint with the MATE desktop is yes a good option, but Cinnamon still works
So the real quests is which desktop environment will run best on the hardware :)
I would start on MATE you can always change it if you like.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
Started out on Mint Cinnamon, but there was some lag going from window to window in browsers, file explorer etc. so I changed it up to Linuxlite.  So far so good.  Seems to use about 500MB less ram in the same tasks.  A little uglier, but its a 1366x786 screen, I'm not really missing much.
Thanks all for the suggestions.
