Fans for case
Go to solution Solved by SpookyCitrus,
8 minutes ago, Catchears said:
Hello all,
I am searching for 140mm (A)RGB case fans. The case in question (Phanteks P350X) comes with one fan (which I will mount at the back as exhaust) and I will be buying the Cooler Master ML240R RGB (don't complain about it) which includes two MF120R ARGB fans. It also comes with a RGB controller and it would be great if the new fans could be plugged into that. Can I simply buy the Cooler Master ML140R ARGB twice? I can get it for €14 here in Germany.
Thanks,
Catchears
Yes, you can just buy the Cooler Master ML140R fans as the extras for the system. It's good to use the same brand fans as the RGB controller you are using so you don't have any incompatibilities.
Hello all,
Thanks,
Catchears
https://linustechtips.com/topic/1078063-fans-for-case/
Hello all,
Thanks,
Catchears
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1078063-fans-for-case/#findComment-12687736
