Hi, I just got onto the forum for the first time.
I was wondering if the following build is a good bang for the buck and if not, please, suggest a substitute which is in the price range. I already have the MOBO so I'm not not planning to change that.
CPU: i5-9400F
GPU: GTX 1660 Ti (MSI Gaming X)
MOBO: ASUS PRIME Z390-P
RAM: 16 GB G.Skill 3200 MHz
CASE: SHARKOON TG4 (RGB)
PSU: ThermalTake Smart SE 730W
Thanks in advance.
https://linustechtips.com/topic/1077453-build-plan-questions/
CPU: i5-9400F
Thanks in advance.
Change what you want, bot post what you want to changed
I lurk
HP Spectre x360 13t late 2019
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Razer Blackwidow Lite
Steelseries Rival 3
https://linustechtips.com/topic/1077453-build-plan-questions/#findComment-12683125
CPU: i5-9400F
Thanks in advance.
It would help to know what the "price range" is.
There is no need for a 700W+ psu in this build and there certainly are much better quality units available at reasonable prices.
You country would help as pricing varies a great deal around the world. Also, you might try using pcpartpicker.com. It does basic compatibility checking and totals power requirements.
https://linustechtips.com/topic/1077453-build-plan-questions/#findComment-12683272
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1077453-build-plan-questions/#findComment-12684428
