CPU: i5-7600K (oc to 4.5)
GPU: RTX 2070
I been having trouble with my fps whenever I play PUBG on my pc. I get decent FPS around 85-110 but I get fps drop every 5 seconds. It drops down to 33 for 1-2 second and goes back up to 85+. Stutters a lot.
Also, my cpu is always at really high usage. I know that it is only 4 cores 4 threads. but is it normal that It is at around 70+% Usage when I have programs like discord, wallpaper engine, steam, spotify, google open?? and when I open a game. the CPU usage goes up to 116% Max. I checked the cpu temperature. It is at 70oC
https://linustechtips.com/topic/1077136-fps-and-cpu-usage/
usually a sense of weak memory.
Desktop benching:
https://linustechtips.com/topic/1077136-fps-and-cpu-usage/#findComment-12680881
1 minute ago, yin990719 said:
I have 16 GB of ram. it is only at 64%
not weak in capacity, but bandwidth and latency
Desktop benching:
https://linustechtips.com/topic/1077136-fps-and-cpu-usage/#findComment-12680889
Just now, _d0nut said:
Full specs? Could be a memory issue.
What program are you using to check CPU and GPU usages? Try to use MSI Afterburner, here's a tutorial on getting that set up
MB: MSI Z270-A PRO LGA 1151 Intel Z270 SATA 6Gb/s USB 3.1 ATX Intel Motherboard
RAM: G.SKILL Ripjaws V Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 2400 (PC4 19200) Desktop Memory Model F4-2400C15D-16GVR
CPU: Intel Core i5-7600K Kaby Lake Quad-Core 3.8 GHz LGA 1151 91W BX80677I57600K Desktop Processor
GPU: MSI GeForce RTX 2070 DirectX 12 RTX 2070 GAMING Z 8G 8GB 256-Bit GDDR6 PCI Express 3.0 x16 HDCP Ready Video Card
Power: Rosewill Glacier Series 600W Modular Gaming Power Supply
SSD: SAMSUNG 850 EVO 2.5" 250GB
HDD: SAMSUNG 850 EVO 2.5" 250GB
https://linustechtips.com/topic/1077136-fps-and-cpu-usage/#findComment-12680891
Just now, yin990719 said:
how do i check the speed. and yes dual channel
it's a 2400mhz kit, although if you didn't set up XMP in the BIOS it should be running at 2133. Shouldn't be an issue
Do this and monitor temperatures and usages of CPU/GPU. Could be a thermal throttling issue
https://linustechtips.com/topic/1077136-fps-and-cpu-usage/#findComment-12680897
CPU is currently 73-78oC I have PUBG, steam, spotify, google, wallpaper engine, discord open
GPU is currently 64oC
https://linustechtips.com/topic/1077136-fps-and-cpu-usage/#findComment-12680901
A huge GPU bottleneck. Get more threads.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1077136-fps-and-cpu-usage/#findComment-12680916
4 minutes ago, yin990719 said:
That's what I was thinking too. But multiple people told me that i5-7600K should be fine with 2070. I'm planning to get an i7-9700K. would that be okay?
you'll need to upgrade your mobo with it. wait for 7/7 and see how the new zen 2 CPUs perform first before upgrading.
https://linustechtips.com/topic/1077136-fps-and-cpu-usage/#findComment-12680925
should I get the 3800X if it performs well? I was planning to not spend more than $400 on the CPU
no need for a 3800x, a 3600 should do just fine.
https://linustechtips.com/topic/1077136-fps-and-cpu-usage/#findComment-12680930
It's not when you have multiple programs open
follow what @Herman Mcpootis said and wait for zen 2
I'd recommend 3600x/3700x right now, but wait for third party reviews to make sure first. You could probably get away with 3600x and overclock it on a decent X470 board
https://linustechtips.com/topic/1077136-fps-and-cpu-usage/#findComment-12680961
I see that 3700X has thermal design power of 65W. is it the lower the better?
https://linustechtips.com/topic/1077136-fps-and-cpu-usage/#findComment-12680969
Consider the i7 7700K + overclock. Cheaper than changing the whole platform.
https://linustechtips.com/topic/1077136-fps-and-cpu-usage/#findComment-12683114
