Try clearing the cmos (use the clear cmos jumper or disconnect the the mobo battery and power supply then hit the power button to drain all power then reconnect everything).
Quote or tag me @Lemtea so I can see your reply.
DAYBREAK: R5 5700X3D | RX 9070XT | 32GB RAM | 1TB 970 EVO PLUSCRUCIAL MX200 1TB SSD | 4TB HDD | CORSAIR TX650M | PURE BASE 500DX | WIN 10
LAPTOP: DELL XPS 15 9570 i7 8750H | GTX 1050TI MAX Q | 16GB RAM | 500GB PCIE SSD | 4K TOUCHSCREEN Win 10 PRO
https://linustechtips.com/topic/1077044-i-need-help/#findComment-12680235
31 minutes ago, Kincaid said:
I have a z390 e Asus motherboard that was working fine this morning but when I tried to turn it on, it turns on for 1/2 a sec than the q leds flash dram cpu dram cpu over and over. How to fix?
I think that should be a lesson, never turn off your PC.  It only takes 120 to 130 watts sitting on the desktop idle.  When you game it is near 300 watts.  400 to 450 watts is the sweet point.  Just leave it on at all times as long as you dont have Jet fans in there hehe.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1077044-i-need-help/#findComment-12680258
