So,my motherboard has only one pin for a chassis fan but my case also includes 2 120mm fans. I know there is a cable that connects the fans with the PSU but i dont know which. Can you help me and if so, does  every PSU have this kind of cable to power the fans?
Thank you
https://linustechtips.com/topic/1076777-fans-cable/
1 minute ago, Schakal_No1 said:
maybe a better solution would be to get a fan splitter - that way you can regulate both fans via software and not have them spinning at a constant speed.
i too would suggest this solution. with a molex / sata adapter your fans will be spinning 100% all the time, which may get noisy. Unless you get an inline adapter.
Couple of options: https://www.amazon.com/s?k=4pin+pwm&ref=nb_sb_noss_1
Gamesystem: X3700, 32GB memory @3200mhz, GTX1080 Hybrid
Unraid system: Epyc 7352, 24/48, 96GB ECC buffered @2666mhz, 2x GT710, GTX1050Ti
https://linustechtips.com/topic/1076777-fans-cable/#findComment-12678091
