First time post, so I’ll get straight to the point
Edit: Apologies if this was supposed to be in the Troubleshooting tab, as I said, first post and I just kinda saw “troubleshooting” under the “motherboard” area
To start off with, my setup is as follows:
i7 7740X
Asus TUF x299 mark 1
EVGA 1080 hybrid cooled
Seagate Ironwolf 2TB drive
As of late, I’ve been having a very strange issue where the BIOS of the board can detect my boot hard drive, but it can't boot to it, and I get an ”Inaccessible boot drive” BSoD. Thing is, diskpart can't see the drive, a new windows install can't see the drive, chkdsk can’t even see the drive.
Things I've tried:
Chkdsk, fixboot, diskpart
Result: None of which worked
New windows install
Result: Windows install didn't see any hard drive
Using SATA to USB to check the drive
Result: Drive is perfectly fine, used chkdsk, fixboot, the whole lot
Edit: I also tried:
SATA to USB directly to the computer
Result: Booted to save mode but couldn’t get to windows. Startup repair couldn’t make heads or tails of it either
Different SATA, SATA power, and SATA motherboard ports
Result: No change in behaviour
Doing Fixmbr on the drive from my laptop
Result: I forgot how or my laptop can’t. Says there isn’t that command
My theory: Recently we had a blackout in the middle of the night from a thunderstorm. My guess is that there was some kind of power surge that did something
I’ll be updating this if I remember anything and if I try something someone's suggested
Edited by _Drive
More info
https://linustechtips.com/topic/1076696-strange-sata-issues/
6 hours ago, Airdragonz said:
Try using a different power cable, a different sata cable, and a different port on your motherboard. If drive still crashes after all that, then it's likely the drive or its disk controller that's bad
Forgot to mention, I have tried different cables, ports, all that. Even used the SATA to USB into my computer. For that one it only booted into safe mode, but never got into windows
Edit: Edited the original post with updated info
Edited by _Drive
Updated
https://linustechtips.com/topic/1076696-strange-sata-issues/#findComment-12678019
My guess is that the disk controller died from possibly that power surge you mentioned. Not really sure if there's any way to extract the data or fix the drive yourself. Your best bet is probably going to be sending the drive to a professional repair center.
print "Hello World!" ("Hello World!")
https://linustechtips.com/topic/1076696-strange-sata-issues/#findComment-12678566
Well, the drive itself is fine. I used the SATA to USB adapter and connected it to my laptop and did a chkdsk, bootfix, and the like on it from there and it seemed okay. Accessed the files alright. I don’t know if I’ve tried the fixmbr command...
Edit: Either I forgot how and did it wrong, or I’m using the wrong command
https://linustechtips.com/topic/1076696-strange-sata-issues/#findComment-12678685
