Building my first ever computer
Go to solution Solved by trevb0t,
11 hours ago, Boinbo said:
Just so you know, you should try and get at least a 240 GB SSD. Also, you can get a used Vega 56 for the same price or cheaper, but will outperform that 1660ti. Even a new one is only $20 more! The PSU @trevb0t recommended can definitely handle it. I'm a little bit skeptical on the RAM choice, but trev, I feel like you would probably know more than me, so you know what you're doing. 3000MHz CL15 does sound nice, not going to lie.
All RAM comes from 3 manufacturers, and the brands we buy have no loyalty to any particular one. All you're really buying when you grab a brand is the heat spreader, and the assurance that they're
tested/graded to work in the pairs given. Unless you're planning to overclock RAM heavily, there is no reason to be snobby about the spreader brand. These are plenty nice, and very hard to argue at the price. The next CL15 model is at least $10-15 more...
Nonsense advice. 120GB is plenty for boot and processes. On a tight budget there is no need to divert more money toward something that makes little performance difference.
10 hours ago, Boinbo said:
Your PSU was fine though, there wasn't anything to change.
EVGA's low tier models aren't great. In fact for the price, a CX series is a pretty big step up. This model just happens to be a small price gap, and a significant quality increase.
11 hours ago, Abdel11 said:
i'm going to consider vega for my build
When on a good sale, their value is hard to argue. The current sales aren't as good as we've seen in the past, but this Sapphire Pulse model is actually a really nice cooler and is the same price currently as the Gaming X 1660Ti you had initially listed.
In most games, this would equate to something like a 20% FPS increase on avg from what I've seen. Titles that favor nVidia will still favor the 1660Ti (Mostly Ubisoft titles like Assassin's Creed. The newest Metro game as well.) But the difference is often negligible. If this were a question of an RTX 2060 or Vega 56, I would swing the 2060 route, but vs the 1660Ti, I would heavily consider Vega.
This example doesn't list the models used, but I find a lot of these guys use a blower reference card for Vega and a multi fan unit on nVidia, since that's what is more readily available respectively. Certainly at the $280 price point. So the results may be better given the Sapphire cooler Vega.
Hello there,
I'm building my first ever computer this summer, after some research i've assembled this build:
-RAIDMAX DELTA I + 2 White LED fans.
-GIGABYTE B450 AORUS M
-RYZEN 2600 6CORE 12 THREADS, with stock cooler
-MSI GAMING X GTX 1660Ti 6GB GDDR6
-T-FORCE VULCAN 2x4GB DDR4 2400MHZ CL14
-SEAGATE BARRACUDA 1TB 7200RPM 64MB CACHE.
-PNY CS900 120GB
-EVGA 500W BR 80 PLUS BRONZE.
What do you think about this setup it's my maximum budget i cannot afford something more than that, are there any reasonable upgrades i can make in the 750$ price range.
https://linustechtips.com/topic/1076644-building-my-first-ever-computer/
Alright. so for ryzen they like fast, dual channel ram. 8GB single sick 2400 mhz would kinda hurt performance. as for storage drives, if you are going to spend money on a HDD and SSD, there are SSDs right now, 1TB models, going for around 90-100$ if you check out the sales.
oh yeah my bad didn't point out that it's 2x4gb of ram and i'm gonna look into ssd and hope to find a good deal thanks mate
Just now, Abdel11 said:
already have one a friend gave it to me
Check this out :) faster ram, the 1TB  ssd, better PSU (in case you decide to upgrade down the road)
I know some would probably eat me for putting a mini-itx board there, but in the time ive built computers, i love m-itx. you only really need 1 GPU, and it comes with 4 sata ports for more storage options later, comes with wifi, and fits literally in any case. and it has 2 m.2 slots in case you want faster storage down the road with NVME drives
oh ok thanks mate looks definitely good
I would wait until reviews of the 3rd ryzen chips come out. (7/7/19)
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
-Moved to New Builds and Planning-
you fricken mods!
THIS NEEDS TO BE A DEMOCRACY!
Also, the newbie should definitely not follow my rebellious examples.
Specs v-v
Just now, Ashiella said:
you fricken mods!
In fairness, unless the OP needs the computer quickly, waiting for new Ryzen would be a better option.
That mess of advice was also pointing out that 2400mhz RAM is going to throttle your CPU's performance. 3000-3200mhz is where you wanna be. 16GB (2X8) would be a much more solid for gaming, since a lot of higher end titles will sit around 8-11GB use.
That PSU needs to go. I'd look at either Corsair CX, Masterwatt Bronze (650W or greater), Pure Power 11... If you can find it at a good price I'd grab a BitFenix Gold.
PCPartPicker Part List
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($145.74 @ SuperBiiz)
Motherboard: MSI - B450M PRO-VDH PLUS Micro ATX AM4 Motherboard  ($69.99 @ Newegg)
Memory: G.Skill - Sniper X 16 GB (2 x 8 GB) DDR4-2666 Memory  ($63.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($43.66 @ OutletPC)
Video Card: PowerColor - Radeon RX VEGA 56 8 GB Red Dragon Video Card  ($309.99 @ Newegg)
Case: Thermaltake - Versa N24 ATX Mid Tower Case  ($39.99 @ Newegg)
Power Supply: Corsair - CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($52.98 @ Newegg)
Total: $726.34
Generated by PCPartPicker 2019-06-27 23:33 EDT-0400
Approximation of your build (Raidmax Delta isn't in PCPartpicker, and there are a few EVGA Bronze units.)
I would swap to something like this:
  • In either build, the Ryzen 5 3600 will be something to look at. It is going to launch for $200, and claims a stronger single core performance.
  • Pro4 and AORUS M quality difference is negligible for how much more the AORUS costs.
  • 16GB DDR4 3000 at CL15. Great RAM at a great price!
  • This 3TB HDD is only $9 more than the 1TB listed. Why not?
  • This Windforce OC model 1660Ti has a stronger boost clock. The cooler is a touch less awesome, so if the plan is to OC, I stick to the Gaming X or grab a decent EVGA model. If you wanna plug and play, grab this one.
  • Case... Grab what you wanna grab. For the price I like this one or the Cougar MX330.
  • CM MWE Gold is gonna blow that EVGA bronze (any given model) out of the water. Solid unit, and well priced currently.
ok thanks for youe help i will stay on the lookout for ryzen 3 as i see it' worth the wait, thanks mate
I lurk
HP Spectre x360 13t late 2019
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Razer Blackwidow Lite
Steelseries Rival 3
I already have another 256GB samsung ssd that i used with my laptop it's the one that i'm going to use for the OS,  and yeah i'm going to consider vega for my build and i changed my ram and psu following the suggestion
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
Oh I just read somewhere on the forums you want at least 240gb SSD. As for the ram issue, okay, good to know.
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
If it's your only drive, I certainly wouldn't go less than 480GB (That's about the capacity of a PS4 or XBone drive, and that holds a handful of big games.)
If you're just going to do all file and game computing off of a HDD, then really a 60GB boot drive would be fine, since currently Windows only uses up less than 11GB. (more like 10.3) and an SSD won't see performance loss often until 70%+ capacity (give or take some for varying drive quality.)
Obviously a larger SSD would give you some space to add a few titles to it. The only real benefit is a bit faster load screens, though.
Alright, thanks for letting me know dude.
I lurk
Core i5 1035g4
8gb ram
256GB NVME SSD
HP 24mh FHD Monitor
OnePlus 5
Jabra evolve 75
Steelseries Rival 3
