Hey guys
Im currently looking for some case and  radiator fans.
I have a Sharkoon TG5 RGB case 3 Thermaltake Pure Plus 12 Fans and for my radiator i have the fans that followed with my AIO for the Thermaltake Water 3.0 360 ARGB SYNC.
Only using 1 of the orignal fans. I've come to a conclusion im not a fan of thermaltakes fans the software is lacky for the Pure Plus fans and the fans that followed the AIO is only compatible with the motherboards RGB software.
Plus the cables are sooooooo long.
So im looking for some fans that have same aesthetics with Controllable RGB fans within the same software that comes with a decent software being able to control fan curve etc.
I need 9 fans in total. 1 in the back 3 in the top and 5 on the rad doing a pushpull config 3 in push 2 in pull (not enough space for a 3rd one).
The radiator is 360*120*25mm Any advice what would be my best solution here?
PC Specs
Ryzen 7 - 2700x - 4.2 Ghz
MSI MPG X570s Carbon Max Wifi
Thermaltake Water 3.0 360mm ARGB Sync TT Premium
G.Skillz Trident Z 3200mhz CL16
Gigabyte RTX 2060 Aorus Xtreme
Samsung Evo 970 - 256 GB
OCZ Agility - 256 GB
Western Digital - 1 TB
Corsair RM750x - 750W Gold
https://linustechtips.com/topic/1076069-case-rad-fans/
